Cos ciekawego
DAN
Obserwuję: M984 L999 L856 P851 M997 M857
Dzisiejsza ciekawostka :
<br>
ACARS mode: O Aircraft reg: F-OHPM [Airbus A340-313 (X)]
<br>
Message label: B9 [Request ATIS information] Block id: 8 Msg no: M72A
<br>
Flight id: PR0001 [] [Philippine Airlines]
<br>
Message content:-
<br>
/LSZH.TI2/024LSZHA89DD-------[ 25/01/2007 14:40 ]-
<br>
a taki jej wygląd <a href="http://www.airliners.net/open.file/1160883/M/" target="_blank">http://www.airliners.net/open.file/1160883/M/</a>
<br>
<br>
I coś z ostatniej chwili <a href="http://www.airliners.net/open.file/1164602/M/" target="_blank">http://www.airliners.net/open.file/1164 ... br>(Maycom AR-108) KRONOS 20X60
Sprzęt: Lornetka KRONOS 20x60, Canon EOS 20D, Uniden Bearcat 9000XLT. Widzę <M984 L999 L856 P851 M997 M857>
DAN
Dzisiejszy rodzynek :
<br>
ACARS mode: O Aircraft reg: YL-BBC [Airbus A320-211]
<br>
Message label: H1 [Message to/from terminal] Block id: 4 Msg no: D846
<br>
Flight id: 6Y0323 Org: AN0323 [Sydney Airport, Australia-Melbourne Airport, Australia] []
<br>
Message content:-
<br>
#DFB/MHUXMAN.A04/CCYL-BBC,MAR04,,05984,02448,19/--------------[ 30/01/2007 15:38 ]-
<br><br>
A tak wygląda : <a href="http://www.airliners.net/open.file/1141728/M/" target="_blank">http://www.airliners.net/open.file/1141728/M/</a>
<br><br>
I jeszcze ten
<br>
ACARS mode: K Aircraft reg: SU-GBD [Airbus A320-231]
<br>
Message label: H1 [Message to/from terminal] Block id: 2 Msg no: D36D
<br>
Flight id: MS0732 [EHRS-ECYC] [Egyptair]
<br>
Message content:-
<br>
#DFBALT,CAS,MN,GW,CG,DMU/-----[ 30/01/2007 16:54 ]-
<br><a href="http://www.airliners.net/open.file/1154032/M/" target="_blank">http://www.airliners.net/open.file/1154032/M/</a>
<br><br>
I jeszcze ten ptaszek
<br>
ACARS mode: O Aircraft reg: SU-BPV [ ]
<br>
Message label: 1L [Off message] Block id: 9 Msg no: M05A
<br>
Flight id: M24521 [] []
<br>
Message content:-
<br>
00002214200EPKT,1721------------[ 30/01/2007 18:03 ]-
<br><br><a href="http://www.jetphotos.net/viewphoto.php? ... 057&nseq=1" target="_blank">http://www.jetphotos.net/viewphoto.php? ... &nseq=1</a>
<br>
Cosik z wczoraj :
<br>
ACARS mode: O Aircraft reg: VT-JWA [Airbus A340-313E]
<br>
Message label: 81 [Off report] Block id: 3 Msg no: M86A
<br>
Flight id: 9W0118 [] [Jet Airways]
<br>
Message content:-
<br>
PUNIT PAREKH PAX ON75G
<br>
HAS LEFT HIS MEDICAL
<br>
PAPERS AT BOM SECURITY.
<br>
REQ FOR ENTRY INTO UK.
<br>
KINDLY FAX SAME TO STN
<br>
MGR LHR ASAP.
<br>
-----[ 29/01/2007 16:37 ]-
<br>
4 contacts with this aircraft. First contact: 12/01/2007 15:52 as flight 9W0122
<br>
Pozdrawiam<br>_________________<br>(Maycom AR-108) KRONOS 20X60</span><span class="gensmall"><br><br>Ostatnio zmieniony przez DAN dnia Czw 17:23, 15 Lut 2007, w całości zmieniany 1 raz</span>
DAN
Dzisiejsza wiadomość:
<br>
ACARS mode: O Aircraft reg: A6-EBR [Boeing B777-31H (ER)]
<br>
Message label: 81 [Off report] Block id: 4 Msg no: M59A
<br>
Flight id: EK0001 [Dubai, UAE-London-Heathrow, UK] [Emirates]
<br>
Message content:-
<br>
/DXBOWEK.HELLO OPS
<br>
PLS INFORM LHR THAT DUE
<br>
TO MEL33-24-01A SEATS
<br>
1JK+2JK ARE BLOCKED
<br>
UNLESS REPAIRED BY LHR
<br>
MAINT. PLS ACKN
<br>
TZON+WINNIE
<br>
Flight Distance: appr. 5503 km Flight time: appr. 6.25 h
<br>
--------[ 13/02/2007 10:12 ]-
<br>
1 contacts with this aircraft. First contact: 13/02/2007 10:04 as flight EK0001
<br>
Pozdrawiam <img src="http://picsrv.fora.pl/images/smiles/icon_smile.gif" alt="Smile" border="0"><br>_________________<br>(Maycom AR-108) KRONOS 20X60
DAN
<br>
ACARS mode: K Aircraft reg: EC-IMU [Airbus A320-214]
<br>
Message label: Q0 [ACARS link test] Block id: 0 Msg no: S28A
<br>
Flight id: TY9301 [] [Iberworld]
<br>
----------------------------------------------------------[ 13/02/2007 14:40 ]-
<br>
1 contacts with this aircraft. First contact: 13/02/2007 14:40 as flight TY9301
<br>
A tak wygląda <a href="http://www.airliners.net/open.file/1066929/M/" target="_blank">http://www.airliners.net/open.file/1066929/M/</a>
<br>
Coś z ostatniej chwili:
<br>
ACARS mode: E Aircraft reg: SU-GBA [Airbus A320-231]
<br>
Message label: H1 [Message to/from terminal] Block id: 0 Msg no: D17A
<br>
Flight id: MS0732 [Berlin, Schoenefeld, Germany-Cairo, Egypt] [Egyptair]
<br>
Message content:-
<br>
#DFBA01/CCSU-GBA,FEB13,145546,EDDB,HECA,0732/
<br>
---[ 13/02/2007 15:58 ]-
<br><a href="http://www.airliners.net/open.file/1170715/M/" target="_blank">http://www.airliners.net/open.file/1170715/M/</a>
<br>
Pozdrawiam.<br>_________________<br>(Maycom AR-108) KRONOS 20X60</span><span class="gensmall"><br><br>Ostatnio zmieniony przez DAN dnia Czw 17:22, 15 Lut 2007, w całości zmieniany 1 raz</span>
DAN
Ciekawostki z dzisiaj :
<br>
ACARS mode: O Aircraft reg: C-GHOZ [Boeing B767-375 (ER)]
<br>
Message label: SA [Media Advisory] Block id: 5 Msg no: S40A
<br>
Flight id: AC0085 [Ben-Gurion International Airport, Israel-Toronto - Lester B. Pearson, Canada] [Air Canada]
<br>
Message content:-
<br>
0EV141110V
<br>
----------[ 15/02/2007 15:12 ]-
<br>
1 contacts with this aircraft. First contact: 15/02/2007 15:11 as flight AC0085
<br>
Fotka : <a href="http://www.airliners.net/open.file/1032112/M/" target="_blank">http://www.airliners.net/open.file/1032112/M/</a>
<br>
A to druga ciekawostka:<span style="font-weight: bold">Royal Netherlands Air Force</span>
<br>
ACARS mode: 2 Aircraft reg: V11 [ ]
<br>
Message label: _ [No information to transmit] Block id: 9 Msg no: M88A
<br>
Flight id: GS0001 [] [General Aviation]
<br>
---------[ 15/02/2007 14:32 ]-
<br>
Fotka : <a href="http://www.airliners.net/open.file/0990653/M/" target="_blank">http://www.airliners.net/open.file/0990653/M/</a>
<br>
Pozdrawiam. <img src="http://picsrv.fora.pl/images/smiles/icon_smile.gif" alt="Smile" border="0"><br>_________________<br>(Maycom AR-108) KRONOS 20X60
Blank
ACARS mode: G Aircraft reg: 9M-MPD [Boeing B747-4H6]
<br>
Message label: 10 [User defined messages/No header] Block id: 5 Msg no: M31A
<br>
Flight id: MH0004 [] [Malaysia Airlines]
<br>
Message content:-
<br>
FRE01M191530080004 19 /LHRKDMH.
<br>
REQUIRE MEDICAL DR
<br>
ON ARRV FOR CREWINJURY IN THE EYES
<br>
----------------------------------------------------------[ 19/02/2007 16:30 ]-
<br>
7 contacts with this aircraft. First contact: 24/10/2006 17:23 as flight MH0004
<br><br>
Doktora !! Doktora !!! <img src="http://picsrv.fora.pl/images/smiles/icon_biggrin.gif" alt="Very Happy" border="0"><br>_________________<br>Samsung Gx-1s + MTO 11CA
<br><a href="http://www.jetphotos.net/showphotos.php?userid=26296" target="_blank" class="postlink"> Moje na j.net </a>
<br><img src="http://img260.imageshack.us/img260/7567 ... bardw5.jpg" border="0">
Pentax K10D+ MTO 11 CA
PawelB
<br><br>
Mogli w Wawie lądować jak kiedyś Virgin z DEL w podobnej sprawie <img src="http://picsrv.fora.pl/images/smiles/icon_biggrin.gif" alt="Very Happy" border="0"><br><br>
Pozdrawiam<br>_________________<br><a href="http://www.jetphotos.net/showphotos.php?userid=19398" target="_blank" class="postlink">Moje JETPHOTOS.NET</a>
<br><a href="http://www.ratownictwo.org.pl/search.ph ... =Pawe%B3+B" target="_blank" class="postlink">Moje fotki na ratownictwo.org.pl</a>
<br><img src="http://img442.imageshack.us/img442/1522/bannerhu7.jpg" border="0">
Blank
No !!
<br>
Hibiscus w Warszawie, to byłoby święto !!<br>_________________<br>Samsung Gx-1s + MTO 11CA
Henry
ACARS mode: K Aircraft reg: N916UA [Boeing B735]
<br>
Message label: Q0 Block id: 7 Msg no: S45A
<br>
Flight id: UA1157 [SFO-SEA] [United Airlines]
<br>
----------------------------------------------------------[ 20/02/2007 12:50 ]-
<br><br>
Trochę dziwne ,ale DAN także to złapał. <img src="http://picsrv.fora.pl/images/smiles/icon_question.gif" alt="Question" border="0"><img src="http://picsrv.fora.pl/images/smiles/icon_question.gif" alt="Question" border="0"><img src="http://picsrv.fora.pl/images/smiles/icon_question.gif" alt="Question" border="0"><br>_________________<br>Sprzęt: Yukon 6-100x100 +Canon A520
Pawel_S
</span><table width="90%" cellspacing="1" cellpadding="3" border="0" align="center">
<tr>
<td><span class="genmed"><b>Henry napisał:</b></span></td> </tr>
<tr>
<td class="quote">ACARS mode: K Aircraft reg: N916UA [Boeing B735]
<br>
<br>
<br>
<br><br>
</td> </tr>
</table>
<br><br>
<br><br>
jest to S7 Syberia <img src="http://picsrv.fora.pl/images/smiles/icon_cool.gif" alt="Cool" border="0"><br><br><a href="http://www.airliners.net/open.file/0990043/M/" target="_blank" class="postlink">http://www.airliners.net/open.file/0990043/M/</a>
<br><br>
ale niegdyś faktycznie był to united
<br><br><a href="http://www.airliners.net/open.file/0577017/M/" target="_blank" class="postlink">http://www.airliners.net/open.file/0577017/M/</a>
<br><br>
pozdrawiam<br>_________________<br>Celestron Skymaster 25x100,Sony DSC-P200
DAN
Dzisiejsza wiadomość <img src="http://picsrv.fora.pl/images/smiles/icon_biggrin.gif" alt="Very Happy" border="0"><br>
ACARS mode: O Aircraft reg: HB-IJI [Airbus A320-214]
<br>
Message label: 45 [?????] Block id: 6 Msg no: M37A
<br>
Flight id: LX1326 [Zürich-Kloten, Switzerland-Moscow (Domodedovo), Russian Federation] [Swiss International Air Lines/Crossair]
<br>
Message content:-
<br>
SUUDD
<br>
HELLO
<br>
PAX MRS. RAVON HAS
<br>
ASKED IF YOU CAN CALL
<br>
007 9162049240
<br>
TO PICK UP HER IN
<br>
DME INSTEAD OF UUEE
<br>
PLS CONFIRM.TKSBRIGARDS
<br>
-----------------[ 22/02/2007 14:51 ]-
<br>
7 contacts with this aircraft. First contact: 20/01/2007 14:09 as flight LX1326
<br>
Pozdrawiam. <img src="http://picsrv.fora.pl/images/smiles/icon_lol.gif" alt="Laughing" border="0"><br>_________________<br>(Maycom AR-108) KRONOS 20X60
Blank
Dzis nad Bałtykiem pojawił się :
<br><br>
ACARS mode: E Aircraft reg: HL7597 [Boeing B777-28E (ER)]
<br>
Message label: H1 [Message to/from terminal] Block id: 9 Msg no: D65A
<br>
Flight id: OZ0521 [Incheon, South Korea-London-Heathrow, UK] [Asiana Airlines]
<br>
Message content:-
<br>
#DFBE99597R521RKSIEGLL220207180750
<br>
56691ER 010004 63WN55192E 12668180750 36001 -64 -38 72 45400
<br>
North: 55.19 East: 12.67
<br>
----------------------------------------------------------[ 22/02/2007 19:08 ]-
<br>
1 contacts with this aircraft. First contact: 22/02/2007 19:05 as flight OZ0521
<br><br>
To ta maszynka w mowym malowaniu
<br><a href="http://www.airliners.net/open.file/1158031/M/" target="_blank">http://www.airliners.net/open.file/1158031/M/</a>
<br><br>
Może kiedys pojawi sie nad Płn-zach Polską <img src="http://picsrv.fora.pl/images/smiles/icon_smile.gif" alt="Smile" border="0"><br>_________________<br>Samsung Gx-1s + MTO 11CA
