Cos ciekawego
DarekG
ACARS mode: O Aircraft reg: B-2561 [ ]
Message label: Q6 [Voice-to-ACARS changeover] Block id: 6 Msg no: S55A
Flight id: HU0481 [] [Hainan Airlines]
----------------------------------------------------------[ 29/03/2006 05:29 ]-
1 contacts with this aircraft. First contact: 29/03/2006 05:27 as flight HU0481
Niestety leciał nad słowacją
ACARS mode: H Aircraft reg: N180DN [Boeing B767-332 (ER)]
Message label: H1 [Message to/from terminal] Block id: 9 Msg no: F59A
Flight id: DL0073 [] [Delta Air Lines]
Message content:-
#M1BREQPWI/TS113044,290306/WQ300.300.300.300:NARKA.KEKED.
LENOV.JED.LDZ.TITAK.GRU.BURAN.DAR.BABIK.REDFI
ROE.ELVIX.MAXUM.SVD.KULUD.ROKAM.MADAG.NORTI.AAL.KOVIK.SORVI.ORVIK.SUM.BESGA.RATSU.6120N.6030N.5840N.5550N.O
----------------------------------------------------------[ 29/03/2006 13:30 ]-
First contact with this aircraft
a ten na UN133
DarekG
Dzisiaj mój acars tak sie pocił i prężył że aż złapał:
ACARS mode: A Aircraft reg: HZ-ANC [McDonnell Douglas MD-11F]
Message label: 5U [Weather request] Block id: 6 Msg no: M89A
Flight id: SV0925 [] [Saudi Arabian Airlines]
Message content:-
22A EBBRELLXCYQG
----------------------------------------------------------[ 22/05/2006 12:36 ]-
Lot z Riyadh do Brukseli :shock:
AceKarol
Ja już go pare razy miałem:
HZ-ANA (MD11F SV) 1154 20060326 SV0923
HZ-ANC (MD11F SV) 1343 20060326 SV0919
Jetphotos | MTO + 350D
Skuter
ACARS mode: G Aircraft reg: B-KAD [Boeing B747-209F]
Message label: 7B [Aircrew initiated miscellaneous message] Block id: 7 Msg no: M59A
Flight id: KA0534 [DXB-MAN] [Dragonair]
Message content:-
PLS CONFIRM ALL CREWS
NEXT DUTY
THKS STEVEN
----------------------------------------------------------[ 25/05/2006 16:38 ]
Kronos 20x60 Maycom FR-100
Canon EOS 350D + 18-55mm
Sigma 70-300mm APO DG
RUBINAR 1000/10
Skuter
ACARS mode: O Aircraft reg: SP-LDD [Embraer Emb.170-100ST]
Message label: H1 [Message to/from terminal] Block id: 8 Msg no: F03A
Flight id: LO0631 [] [LOT Polish Airlines]
Message content:-
#CFBACMF SNAPSHOT REPORT 2006MAY27 10:09:21
A/C SP-LDD
SWVER 16.4 APPVER 1.1.0 APPNAME OEM.ACM
SIZE 1886
DL_CRUISE_REPORT_20060527100921S.CSV
ERJ170LDI17.2V16.4_F_V03R 2006MAY27 10:09:21 T 2006MAY27 10:09:2
----------------------------------------------------------[ 27/05/2006 12:09 ]-
Message label: H1 [Message to/from terminal] Block id: 0 Msg no: F03C
Flight id: LO0631 [WAW-SOF] [LOT Polish Airlines]
Message content:-
#CFBCmd
0
Engine1_ChannelinControl
1
Engine1_FADEC_Fan_In_Temp
-24.0781
Engine1_FADEC_SAT
399.875
Engine1_FuelFlow
1912.25
Engine1_ITT
762.375
Engine1_N1
85.6718
Engine1_N2
84.7343
Engine1_OilPress
72.2857Engi
----------------------------------------------------------[ 27/05/2006 12:10 ]-
1 contacts with this aircraft. First contact: 27/05/2006 12:09 as flight LO0631
Message label: H1 [Message to/from terminal] Block id: 1 Msg no: F03D
Message content:-
#CFBne1_OilTemp
88.0293
Engine1_TLA
60.0625
Engine1_n1CorrectedFanSpeed
92.1562
Engine1_n1Vibe
0.185546
Engine1_n2CorrectedFanSpeed
84.5312
Engine1_n2Vibe
1.08593
Engine1_oatSet
15
Engine1_ps3Cdp
125.875Engine
Message label: H1 [Message to/from terminal] Block id: 2 Msg no: F03E
Message content:-
#CFB1_t3About
406.812
Engine1_vgAngle
-1.75
Engine2_ChannelinControl
1
Engine2_FADEC_SAT
399.875
Engine2_Fan_In_Temp
-23.6562
Engine2_FuelFlow
1908.5
Engine2_ITT
760.625
Engine2_N1
85.6875
Engine2_N2
84.6875En
Message label: H1 [Message to/from terminal] Block id: 3 Msg no: F03F
Message content:-
#CFBgine2_OilPress
70
Engine2_OilTemp
91.1013
Engine2_TLA
60.5625
Engine2_n1Corrected_fan_speed
92.0781
Engine2_n1Vibe
0.4375
Engine2_n2Corrected_fan_speed
84.4375
Engine2_n2Vibe
2.35156
Engine2_oatSet
15Engin
Message label: H1 [Message to/from terminal] Block id: 4 Msg no: F03G
Message content:-
#CFBe2_ps3Cdp
124.625
Engine2_t3About
406.562
Engine2_vgAngle
-1.5625
HPSOV_VLV_OPNLeft1
0
HPSOV_VLV_OPNLeft2
0
HPSOV_VLV_OPNRight1
0
HPSOV_VLV_OPNRight2
0
Mach
0.800274
Pack1
0
Pack1_Flow
35.1171
Pack2
0Pack2
Message label: H1 [Message to/from terminal] Block id: 5 Msg no: F03H
Message content:-
#CFB_Flow
36.0546
Press_Alt
34002.5
SAI_Config_Disc1
0
SAI_Config_Disc2
0
SAT
-51.1327
SlatAI_Left
0
SlatAI_Right
0
TotalAirTemp
-22.6937
e1n1avib
0.0820362
e1n1bvib
0.0351584
e1n2avib
0.140633
e1n2bvib0.40627
----------------------------------------------------------[ 27/05/2006 12:11 ]-
Message label: H1 [Message to/from terminal] Block id: 6 Msg no: F03I
Message content:-
#CFB4
e2n1avib
0.191417
e2n1bvib
0.0351584
e2n2avib
0.359396
e2n2bvib
0.878959
Ktoś wie oco w tym chodzi :roll: :-) ??
RUBINAR 1000/10
DarekG
Skuter są to standardowe depesze wysyłane przez nasze E170 nie wiem dlaczego tylko przez nasze :-?
bartek15
hmm...zaciekawiło mnie i nieco zdziwiło bo wpisując w acarsie reg. D-ALCG wyskoczyła taka depesza:
ACARS mode: 1 Aircraft reg: N619FE [McDonnell Douglas MD11F]
Message label: ** Block id: @ Msg no: 0055
Flight id: MD0011 [BKK-TNR] []
----------------------------------------------------------[ 27/05/2006 20:31 ]-
i taka(to mniej dziwne bo wykonuje loty dla Air Madagascar)
ACARS mode: 1 Aircraft reg: D-ALCG [McDonnell Douglas MD11F]
Message label: ** Block id: @ Msg no: 00ff
----------------------------------------------------------[ 28/05/2006 16:05 ]-
Message content:-
A/C SP-LDD
SIZE 1886
First contact with this aircraft ...........................
Właśnie miałem o to samo pytać :-) dziś mi się spowiadał SP-LDH on flight LO0603
Skuter
ACARS mode: G Aircraft reg: LZ-BHE Org: EI-DNK [Airbus A320-211]
Message label: 4P [Change Acars mode ] Block id: 3 Msg no: S60A
Flight id: ACGATE [] [Air Canada]
Message content:-
E120A128G0//
----------------------------------------------------------[ 09/06/2006 15:18 ]-
RUBINAR 1000/10
bartek15
heh ciekawe...obecnie lata jako Balkan Holidays Air i to wlasnie złapałeś lot BGH5505/06 z SOF do nie wiem gdzie...i dziwne że tak się pokazuje w acarsie...
bartek15
ACARS mode: O Aircraft reg: A9C-HMK [ ]
Message label: B9 [Request ATIS information] Block id: 2 Msg no: M18A
Flight id: LHBAH1 [] [Lufthansa]
Message content:-
/EDDH.TI2/024EDDHA3349
----------------------------------------------------------[ 11/06/2006 11:08 ]-
1 contacts with this aircraft. First contact: 11/06/2006 11:06 as flight LHBAH1
Ciekawe czemu Bahrain Amiri Flight pokazuje sie jako LH :?:
Skuter
ACARS mode: 2 Aircraft reg: VH-OEB [Boeing B747-48E]
Message label: 87 [Aircrew addressed downlink] Block id: 2 Msg no: M35A
Flight id: QF0032 [WGLL-WSSS-YSSY] [Qantas]
Message content:-
HI. PAX REQST FOR SCORE
OF ENGLAND V AUS IN
RUGBY UNION.
THANX
----------------------------------------------------------[ 11/06/2006 15:17 ]-
1 contacts with this aircraft. First contact: 11/06/2006 15:15 as flight QF0032
Kto zna wynik :-D ??
RUBINAR 1000/10
