Hi.
I need help uploading images, as I have a lot of images to show you all but Im not sure how to upload image thumbnails from photobucket.I want to get a small icon instead of the full size picture. This way I can upload my pictures without taking up as much space.
Thanks.
							Uploading Images
Hi there!
Once you have your Photobucket album opened, you can see that next to each of the photos there is a check box. You can select one or more of your photos. Then select the button at the bottom of the current page which is called 'Generate HTML and IMG code'. A new page opens with number of codes listed. Copy the code(s) from the third textbox named 'IMG clickable thumbnails for message boards' and paste it into the forum message.
Cheers
Cheers
